As the title implies, I have a circular sketch which I want to revolve around an axis which is tangent to the circle. Unfortunately, the feature will not complete, and the error textbox appears stating that "Sketch is open, self-intersecting, or intersects the center-line". The object looks like this:
Hi Esspen,
SolidWorks can't create a self-intersecting geometry, zero thickness etc.
But if you shift the centre line with 0.01mm away from circle it will work.
