Hello all,
I am trying a challenge to model a screw with the thread following a helical path with the thread getting smaller as it goes towards the tip. See screen shot. I am using a Loft with 2 sections and the feature starts off ok, but the cross section folds onto itself, see 2nd screen shot. Can any one tell me what's wrong here? I have also attached the part file.
Thanks in advance!
Peter
Hi Peter,
I see what you mean. I tried a few settings in the command and was able to get solid geometry out of it but it was not a desirable result so I'll send this off to our Quality and Development teams to look at it to see if there is something we can fix. A good thing to do is contact your SOLIDWORKS reseller and ask them to file a bug on your behalf so that you get notified when it is fixed.
But in the mean time, I think what you are trying to do is to get the "thread" to taper into the model. If that is true, why not simply use a single variable pitch sweep? I've done that in a new model for you to see how it works.
On a side note, we now have a Thread command in 2016 that will make creating threads much easier and faster. For now you can use our existing thread profiles or create your own but there's no option to taper it (yet).
Good luck with your project.
Jody
