Help! I have been trying to download solidworks onto my computer. I can start the setup file, but part way through the download, it says that a version of bonjour (whatever that is) has already been downloaded: it then says I can continue downloading, but might run into problems.
I then run into problems, as I am prompted that the "Windows Installer for this product component did not run as expected: LaunchConditions"
What should I do?
Bonjour is a bit of software used by several programs that deals with network things that the user then doesn't have to worry about.
You have a later version installed already then that the SW version you're trying to install needs.
To be exact, you are trying to install SW'15 SP2.1 while your system has a more up to date Bonjour installed.
Could very well be that if you install SP3 or SP4 that you wouldn't get that error message.
I also noticed from your log files that you're installing it along side a previous release which although theoretically shouldn't pose a problem in practice it can sometimes do cause problems.
On a side note:
I would advise you to use the "download and share all files" option or the Administrative image option during download.
