In EPDM list using SQL query, I want to display all the users in a particular group, with the capacity to designate all users from multiple groups.
Oh, And I'd also like the resulting list to include one or more values that I specify, which are not userids in any group, such as "TBD" or "NA"
Thanks!
Paul,
I wrote something like that for another customer. The query below should get you started.
select '' as Fullname --This is your additional option. A blank value in this case, but could be 'N/A'
union
select distinct U.FullName
from Groups G, Users U, GroupMembers GM
where G.Groupname = '' -- Enter group name here between the single quotes.
and G.GroupID = GM.GroupID
and U.UserID = GM.UserID
and U.Enabled = 1
--For mulitple groups, add another union command here and then re-use the group member syntax from above and search for a different group name.
order by Fullname
Derek M. Lawson
