Hey there,
I am struggling to figure out why this lofted boss extrusion is not working. It is the part on an acoustic guitar that is attached to the back of the neck and mounts to the body of the guitar. As you can see the shape gets twisted and jumps out of its boundaries. I am so confused; I thought I knew how to solidworks...
Please help!!
Thank you,
Ben
Hard to tell exactly what is going on from your pictures.
One thing about lofts. Always have the same number of segments in every section!
It seems you are trying to loft four segments (two lines and two arches) into two segments (one line and one arc). This will rarely work.
Try to split the line, the arc or both so you will have four segments in each section and try again and play with the placement of the splits.
Maybe you could add fillets in the two-segment sketch.
