Is there a way to combine the inner and outer cutting length values in the sheet metal cut list properties? If so, is there a way to edit/save the cut-list template to reflect this on every sheet-metal part created. It know its as simple as adding the two values together, but I would prefer to have a single "linked" value/annotation on my drawings that updates with any changes to the part. Our fabrication department uses the total cutting length as a basis for there quoting and I would prefer not to rely on them manually adding these two numbers together and possibly getting an incorrect value. Any help is appreciated.
Well, I've found an interesting workaround for the equation. Instead of Cut-List, if you use an indented BOM table you can set the table column for equations and after you save that table template it will maintain the equation. Downside is that there will be a blank row, but you can easily right-click to hide or delete. This situation seems prime for an enhancement request...
