hy guys,
can anyone tell me if a could make a hole table from a 'dwg' file? I tried everything i could but with no result.
i attached the file i wanted to make the table from.
thanks in advance!
hy guys,
thanks in advance!
Yes,,, I used to do this quite frequently on part with lots of holes so I could count them up for quoting purposes. You do have to extrude your part sketches to make a solid. Bring that into a drawing then apply the hole table. Combine tags. You can see in the pic below that it does not do obrounds.
