Hi All
I created an Exploded view, that I later deleted. It has left some hidden "Body-Move/Copy" features, that I guess is used in the explode feature itself, but they are now causing errors when rebuilding. Is there a way to show these hidden/background features in order to delete them?
Running SW2015
Cheers - Anders
I am using SW2014 SP5.
I believe I may have stumbled upon a solution for this issue - one that I have faced a number of times.
Find the body with the offending hidden Move/Copy Body feature within the cut list. RMC on this body and select Parent/Child Relationships. In the Children window you should see a Move/Copy Body feature listed. RMC this feature in the list and select Delete.
Done.
I just discovered this and have only worked it on one part file but it succeeded every time on multiple bodies.
