When I go to flatten a route in Solidworks the wires no longer run to their proper connection point.
I am trying to make a flattened route look something similar to this picture I found online, where you see each individual wire at the beginning and then it it turns into a cable or harness. https://www.mcad.com/wp-content/uploads/Electrical_Creating_Harness_Drawing_Edit_Route.jpg
Attached is what I am seeing.
I am using Solidworks Electrical to make this and I am inserting components that have connection points for each wire as well as a cable point which is a 1/4 inch off of its face. then I am drawing a routing path and using the route harnesses features.
