I am trying to check in an assembly. The assembly is rather
large. When I click on the "check in active" button it displays a
status box and begins searching the world. It is searching folders
more than once and I am going onto 30 minutes now.
I had success with an assembly earlier. It took 10 minutes for it to finish searching and it only has 3 parts.
I have cleared out everything in the references folders under options except for My Documents. I also cleared the checkbox under that that says something like search SWx referenced file locations.
It has never taken this long before... what is it doing?
I have no clue. I never had any problems with speed on check in/out. What versions are you running?
Regards,
Flemming
