As the first step of implementation, we will be use the Create PDF Add-In to create drawing files outside of the Vault on another network drive ("N:\"). We would like to keep the same directory structure outside of the vault as inside on the "mirror". The Create PDF Task includes specification of the Default Path, but this always includes the local drive name. These essentially become additional directories on the target N:\ drive. The example under default path is "N:\C:\Vault\Part.pdf".
When generated, the "C" and "Vault" directories are not needed and are confusing for our users outside of engineering. We would like to keep the path without the root drive or vault name.
KB solution S-061104 describes some modifications that may be similar, but I have been unsuccessful in modifying Advanced Scripting Options to date.
Any help would be appreciated.
In the output file details change the default output path to source location so it's trying to put the file in C:\Vault\Somefolder\somfile.pdf.
Then in the script modify the variable "convFileName" to change the C:\ to N:\ after this line:
' Build destination filenames
convFileName = "[OutputPath]"
convFileName = Replace(convFileName, "C:\", "N:\") ' <-- Add this line
If you do this you will want to make a copy of the task because that script modification will make the task always do this so it becomes useless for any other function.
Also I believe i read once that script modifications are reset if the add-in is updated, or maybe it was even just epdm? In any case you'll want to make note of this somewhere so you know to modify it again if need be.
I have not tested this. If it doesn't work follow that variable around the code and see what changes it and maybe just set the convFileNameTemp directly prior to the swExtension.SaveAs. Just make sure you do so in every applicable spot.
