I need to add a dimension between Points 1 & 2 that is paralleled to A line. ( just like the following image).
Smart Dimension adds only Vertical,horizontal or the shortest distance between these two points.
At present to add dimensions like this, I add a construction line that is perpendicular to A line and then add the dimension I need.
Is there any way to add this dimension without adding a construction line?
thank you.
In the drawing you can use align to edge but sorry not available for model sketching.
