I would like to change the toolbox flag on some parts in EPDM but through some experimenting have found that you cannot seem to change the property if the part is in EPDM. Does anyone know of a workaround for this limitation? I thought of copying all the parts I want to do to outside the vault and then putting them back in, would work but just asking if anyone has found a better way.
Hi Steve,
We also encountered this issue and the only solution is to make changes outside PDM, as you said.
We must also delete the file from PDM and than copy file from outside. Only overwriting is not working.
