I have 3 part drawings and i need to create an assembly drawing with those. How do I do? Should I convert the part drawings to part models and then assemble in 3D and then convert that assembly to assembly drawing?
Or can I directly combine 3 part drawings into an assembly drawing?
Please answer my question. Thanks in advance.
-Arun
You can combine the individual drawings into one. Open each drawing, right-click on the sheet tab at bottom, and choose "Copy". Open the new drawing, right-click at bottom again, and choose "Paste". You'll get a pop-up asking where to paste. Choose the appropriate answer and Okay. This will add (2) at the end of the sheet name, but you can remove it by re-naming the sheet. Repeat for each sheet.
