Component Pattern
Question asked by Arvind Purushotaman on Oct 7, 2015
Hello Guys,
Can someone please help me with dissolving a pattern in an assembly. I am working on an internship and I need this feature to proceed ahead. Searched in the blog but could not find the right answer.
My code is as follows:
Dim swApp                       As SldWorks.SldWorks
Dim swModel                     As SldWorks.ModelDoc2
Dim swfeat                      As SldWorks.Feature
Dim swComp                      As SldWorks.Component2
Dim swRootComp                  As SldWorks.Component2
Dim swConfMgr                   As SldWorks.ConfigurationManager
Dim swConf                      As SldWorks.Configuration
Dim partname                    As SldWorks.Component2
Dim swAssy                      As SldWorks.AssemblyDoc
Dim swModelDoc                  As SldWorks.ModelDoc2
    Set swModel = swApp.ActiveDoc
    Set swAssy = swModel
    Set swfeat = swModel.FirstFeature
    Set swConfMgr = swModel.ConfigurationManager
    Set swConf = swConfMgr.ActiveConfiguration
    Set swRootComp = swConf.GetRootComponent3(True)
    While Not swfeat Is Nothing
        If swfeat.GetTypeName2 = "Reference" Then
            Set swComp = swfeat.GetSpecificFeature2
            If UCase(Right(swComp.GetPathName, 3)) = "ASM" Then
               MsgBox "Assembly:" & swComp.Name2
            ElseIf UCase(Right(swComp.GetPathName, 3)) = "PRT" Then
               MsgBox "Part :" & swComp.Name2
        If swfeat.GetTypeName2 = "ReferencePattern" Then
            swfeat.Select (False)
            swModel.DissolveComponentPattern
        Set swfeat = swfeat.GetNextFeature
    Wend
Someone please guide me.
Thank you
