Hello Guys,
Can someone please help me with dissolving a pattern in an assembly. I am working on an internship and I need this feature to proceed ahead. Searched in the blog but could not find the right answer.
My code is as follows:
Dim swfeat As SldWorks.Feature
Dim swRootComp As SldWorks.Component2
Dim swConfMgr As SldWorks.ConfigurationManager
Dim swConf As SldWorks.Configuration
Dim partname As SldWorks.Component2
Dim swModelDoc As SldWorks.ModelDoc2
Set swModel = swApp.ActiveDoc
Set swAssy = swModel
Set swfeat = swModel.FirstFeature
Set swConfMgr = swModel.ConfigurationManager
Set swConf = swConfMgr.ActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
While Not swfeat Is Nothing
If swfeat.GetTypeName2 = "Reference" Then
Set swComp = swfeat.GetSpecificFeature2
If UCase(Right(swComp.GetPathName, 3)) = "ASM" Then
MsgBox "Assembly:" & swComp.Name2
ElseIf UCase(Right(swComp.GetPathName, 3)) = "PRT" Then
MsgBox "Part :" & swComp.Name2
If swfeat.GetTypeName2 = "ReferencePattern" Then
swfeat.Select (False)
swModel.DissolveComponentPattern
Set swfeat = swfeat.GetNextFeature
Wend
Someone please guide me.
Thank you
replace
with
