2 Replies Latest reply on Oct 7, 2015 5:45 PM by Seth Ruhan
    check whether bom exists
    Mario Zahren
      Hello all,
      is there any way to check whether bom exists in a drawing or not? I can not find any snippets...
      Any help would be appreciated.
      Mario
        • Re: check whether bom exists
          Simon Turner
          Loop through all the views in the drawing.
          Use IView::GetFirstTableAnnotation and ITableAnnotation.GetNext
          followed by checking ITableAnnotation.Type = swTableAnnotation_BillOfMaterials
            Seth Ruhan
            Snippets
            Public Shared Sub CheckDrawing(ByVal swModel As ModelDoc2)
                    Try
                        If swModel.GetType <> swDocumentTypes_e.swDocDRAWING Then
                            Exit Sub
                        Dim DwgDoc As DrawingDoc = swModel
                        Dim swFeat As IFeature = DwgDoc.FirstFeature
                        Dim swBomFeat As IBomFeature
                        Do While Not swFeat Is Nothing
                            If "BomFeat" = swFeat.GetTypeName Then
                                swBomFeat = swFeat.GetSpecificFeature2
                                ProcessBomFeature(DwgDoc, swBomFeat)
                            If "WeldmentTableFeat" = swFeat.GetTypeName Then
                                ProcessWeldmentBOM(swFeat)
                            swFeat = swFeat.GetNextFeature
                        Loop
                    Catch ex As System.Exception
                    End Try
                Private Shared Sub ProcessBomFeature(DwgDoc As DrawingDoc, swBomFeat As BomFeature)
                    Dim vTableArr As Object
                    Dim vTable As Object
                    Dim vConfigArray As Object
                    Dim vConfig As Object
                    Dim ConfigName As String
                    Dim swTable As ITableAnnotation
                    swFeat = swBomFeat.GetFeature
                    vTableArr = swBomFeat.GetTableAnnotations
                    For Each vTable In vTableArr
                        swTable = vTable
                        vConfigArray = swBomFeat.GetConfigurations(True, True)
                        For Each vConfig In vConfigArray
                            ConfigName = vConfig
                            ProcessTableAnn(swBomFeat, swTable, ConfigName)
                        Next vConfig
                    Next vTable
            Shared Sub ProcessTableAnn(swBomFeat As BomFeature, swTableAnn As ITableAnnotation, ConfigName As String)
            'Do stuff here
            end sub
            Shared Sub ProcessWeldmentBOM(Feat As IFeature)
                    Try
                        Dim CutListFeat As IWeldmentCutListFeature = Feat.GetSpecificFeature2
                        Dim swTableAnn As ITableAnnotation = CutListFeat.IGetTableAnnotations(CutListFeat.GetTableAnnotationCount)
                        Dim CutListAnnotation As IWeldmentCutListAnnotation = CutListFeat.IGetTableAnnotations(CutListFeat.GetTableAnnotationCount)
                        If swTableAnn.Type = swTableAnnotationType_e.swTableAnnotation_WeldmentCutList Then
                                'Do stuff here
                    End Try
