i am trying to search in the vault via API (VB.net) with the condition "IsNotEmpty". But i cant get it to work
Dim con As PDMWorks.PDMWConnection Dim Options As PDMWorks.IPDMWSearchOptions Dim results As PDMWorks.IPDMWSearchResults con = CreateObject("PDMWorks.PDMWConnection") con.Login("pdmwadmin", "pdmwadmin", "hmtechv") Options = con.GetSearchOptionsObject Options.IgnoreCase = True Options.IgnoreLinks = False Options.SearchConfigSpecificProperties = False Options.IncludeHiddenDocuments = True Options.SearchOnlyChildrenOf = "" Options.SearchCriteria.AddCriteria(PDMWorks.PDMWAndOr.pdmwAnd, PDMWorks.PDMWPropertyType.pdmwNumber, "", PDMWorks.PDMWConditionType.pdmwIsNotEmpty, "") results = con.Search(Options) MsgBox(results.Count) con.Logout()
I get no result.
If i change the search criteria to (with Value = "-")
Options.SearchCriteria.AddCriteria(PDMWorks.PDMWAndOr.pdmwAnd, PDMWorks.PDMWPropertyType.pdmwNumber, "", PDMWorks.PDMWConditionType.pdmwIsNotEmpty, "-")
I get after a long search (much longer than in SolidWorks...about 5 minutes) a result of many documents (much more than in SolidWorks). The results contains also dicuments with empty Number property.
What i am doing wrong?
Regards
