HI
HOW TO INSERT POSITION OF WELDING (1G, 2G ,....) WHEN WE USE WELD BEAD , AND THEN INSERT IN WELD TABLE ?
HI
TANKS MARK
I HAVE 2 WELD POSITION (1G & 3G) BY SAME MATERIAL AND METHOD OF WELDING .HAVE CAN I INSERT THEM ON THE TWO SEPARATE GROUP. NOW THE ONLY WAY IS TO ASSIGN DIFFERENT BEAD SIZE TO CRATE SEPARATE GROUP , BUT MY CONFIGURATION IS :
1) SMAW - 1 G- BEAD SIZE 5 mm
2) SMAW - 3 G- BEAD SIZE 5 mm
HOW YOU INSERT NEW WELD GROUP BYE SAME BEAD SIZE ACC. TO ABOVE PICTURE( 12 mm FILLET )
Hi Adel,
Don't know how you would have different weld methods showing for same types of weld.
The only way I can think of is to put a unique size weld in for the second size.
For example a 10mm for vertical 3G & something stupid like 10.01mm for the 1G horizontal weld.
Then edit your weld table and break the link of the 10.01 size, and change back to 10mm.
Unfortunately this means if you update your model you would have to delete your table and re - do..
Mark
any one?
