I've attached an approximation of the parts I'm working with.
I need to mate the board into the sockets in such a way that when I change the distance mates, I can determine if there is interference between the board and the connectors. One direction was pretty simple, but the customer's application has them connectors offset in two directions, causing me a compound angle headache. The board is a PCB and does not bend very well.
Any ideas?
I tried adding some planes that reflect the connectors' positioning and then mated the board to these planes.
Then I ran interference detection.
I don't know if this suffices, but the logic may get you closer.
Cheers,
Kevin
