Is there a way to create/insert a duplicate sheet in a drawing?? I want to use the sheet I have, properly set up with views and notes and dimensions, to make a second sheet with a different configuration referenced in the views. I usually just SAVE AS a separate file and switch configs, but what if I want them to be in the same file?
In the drawing, select the Sheet tab at the bottom of the page, RMB Copy, then RMB Paste (I typically choose "after selected sheet" in the dialog box that opens).
