I know there have been previous posts on this, but still haven't found an answer to the question I have. I need to be able to have a BOM to a top level assembly on multiple sheets, and I need to make sure the item numbers are the same on both (otherwise this becomes a very manual and tedious process). Is there any way to do this, I know you can copy a sheet but if you re-order parts it doesn't seem to propagate to the copied sheet. And from what I have seen so far you can only have one BOM linked to one in an assembly model. I hope someone knows the answer to this problem, it would sure make shop files much nicer to make.
To answer the question I know is going to come up: Why do you need to have the same BOM on multiple pages? Well, my assemblies get quite large and it is difficult to show the exploded view on a single sheet, it is also very difficult to break them down into logical sub-assemblies.
In SWX '15, you can insert BOM on all the sheets and select option "Follow assembly order".
