Hello All,
I'm having an issue with hidden lines showing partially as solid lines, while others do appear as they should. Basically, I had a Tekla model from our detailer, and because the coordinate system was all screwed up to what I needed, I used the reference geometry / coordinate system option to set a new origin and x/y directions, then saved out as a STEP file, them re-imported back in and saved as an assembly file. But now as a result, when I make some detail views of the model, the lines appear incorrect as far as linetype. I think with all the conversion process, something got messed up. See below. From reading other posts on this forum, I don't believe I can change the linetype or linetype scale of a detail view (from the Options / Document settings)? Thanks in advance.
Dave,
For this case I'd suggest using the Line Format toolbar to change the line types for the ones that are wrong.
