I need to create a solid model of a Shelby Cobra . I found an open source IGS file. My plan was to make a solid by importing the file, closing off open areas with surface fills (wheel wells, undercarriage, cockpit, etc), knit the surfaces together, and then "Try to form solid" or use the "Cut with Surface" feature on an extruded solid block.
When I made the surface fills, I drew curves as guide lines and used adjacent edges. This is my first experience with surfaces, and I'm having an incredibly difficult time getting rid of these gaps. I would greatly appreciate some help.
I've attached two files. "AC Cobra.IGS" is the original open source file. "AC Cobra scaled" is my version with the surface fills.
It looks one major source of issues is in mirror 3, where you mirror the filled surface on the front of the car. There are a lot of large gaps there that solidworks isn't able to knit together. I'd suggest redoing that surface manually and then stepping through your model feature by feature knitting each surface together to check for other points where the model isn't coming together right.
