I am trying to combine two parts I have made into 1 part. I realize that I can make them an assembly and than save it as a part but than the part turns into surfaces instead of editable features. Is there a way to join the two parts. I tried using the join command but I get an error about zero thickness.
in one part, go to insert -> part and select the other part. if you want to bring the features in, make sure you select the option to "break link" to existing file.
