Hi guys,
I am quite new to solidworks. I've got a lot of experience in 3dsmax but that's a complete different way of modeling.
I will explain my problem with an image:
Swept Cut will leave both ends open. Extruded cut will leave both ends closed. The top needs to be closed and the bottom needs to be open.
There is a Draft On/Off function but this will taper all sides inwards. I would like to chose which sides should go inwards.
Anybody knows a way to solve this?
Best,
Ronald
Draw your L shape sketch so the top edge is co-incident, and the right hand edge is beyond the surface you are drawing on.
