Has any one experienced not being able to change a 2D sketch line into a construction line
The area in question is circled with a polyline at the sketch level
of this part.Some lines allow to change others not.
Hello Greg,
I suspect it's because of the complexity of the sketch. I opened it, box-selected those entities, and chose the "Make Construction" icon. They didn't change to construction so I started clicking on individual lines. Most of them had "Make Construction" grayed out in their PropertyManager, but when I clicked on one of the circles it wasn't grayed out, and was selected. I un-checked the box, then checked it again. When I did that then all the lines I had previously selected turned to construction lines. I hope this helps.
This is correct behavior you're seeing. When there is a complex sketch, then "Automatic Solve" goes off by default. So you need to set it to on.
Once you set that on, then you can set the selection to construction geometry as required.
