This picture is of a drawing of a flat pattern. The 5.63 is dimension-ed to the arc and the 7.20 is dimension-ed to the cener-line of the slot. The 5.63 matches the cut in the flat part. What is up with the 7.20? Obviously something because the arrowheads are showing up a little different as well. This is some functionality I cannot figure out. Any ideas?
Just guessing,
Maybe you should check if the drawing view is set up for true or projected dimensions. 2012 SOLIDWORKS Help - Dimension Type
If it´s on true change it to projected manually.
