Dissolving all the sub-assemblies in an Assembly - including sub-assemblies inside a sub-assembly
Question asked by Arvind Purushotaman on Sep 26, 2015
I wrote a code around a logic by which we can dissolve sub-assemblies inside another sub-assembly. I was not able to achieve the objective of dissolving. I went through one of the author's code (Keith Rice) but still I am a bit confused.
Here is my code, can some kindly help me out?
Dim swApp                       As SldWorks.SldWorks
Dim swModel                     As SldWorks.ModelDoc2
Dim swAssem                     As SldWorks.AssemblyDoc
Dim swFeat                      As SldWorks.Feature
Dim swComp                      As SldWorks.Component2
Dim swRootComp                  As SldWorks.Component2
Dim swConfMgr                   As SldWorks.ConfigurationManager
Dim swConf                      As SldWorks.Configuration
    Set Part = New Collection
    Set swModel = swApp.ActiveDoc
    Set swAssem = swModel
    Set swFeat = swModel.FirstFeature
    Set swConfMgr = swModel.ConfigurationManager
    Set swConf = swConfMgr.ActiveConfiguration
    Set swRootComp = swConf.GetRootComponent3(True)
    While Not swFeat Is Nothing
        If swFeat.GetTypeName2 = "Reference" Then
            Set swComp = swFeat.GetSpecificFeature2
                If UCase(Right(swComp.GetPathName, 3)) = "ASM" Then
                    MsgBox "Name : " & swComp.Name2
                    Call Dissolve(swComp)
        Set swFeat = swFeat.GetNextFeature
    Wend
Sub Dissolve(prt As SldWorks.Component2)
Dim Children                    As Variant
Dim ChildComp                   As Component2
Dim Aparts                      As Integer
Dim Pparts                      As Integer
Aparts = 0
Pparts = 0
Dim swcompModel                 As SldWorks.ModelDoc2
Dim swcompAssy                  As SldWorks.AssemblyDoc
Dim test                        As Boolean
               Children = prt.GetChildren
               For i = 0 To UBound(Children)
                   Set ChildComp = Children(i)
                   If UCase(Right(ChildComp.GetPathName, 3)) = "ASM" Then
                      MsgBox "Name 2 :" & ChildComp.Name2
                      Aparts = Aparts + 1
                      Call Dissolve(ChildComp)
                   Else
                      Pparts = Pparts + 1
               Next i
               If Aparts = 0 Then
                Set swcompModel = prt.GetModelDoc2
                Set swcompAssy = swcompModel
                prt.Select4 False, Nothing, False
                test = swcompAssy.DissolveSubAssembly
Thank you,
Arvind
