I am trying to draw a model of our current Extruder screw but cant seem to get the sweep to work for the flights of the sccrew. I keep geeting an open profile error message but my profile is not open.
I am assuming you have a center core or pipe before you drew the flights and that you are making it as a single part rather then an assembly with different parts.
If that is what you're doing then there is a gap between the flighting and the pipe, so you can extend the flighting profile sketch into the pipe and then it should work... etc..
