After using Cutting Planes to create a nice looking cut-a-way view, the render mode changes from Shaded Illustration to Smooth.
Is this a bug in V2013? Is there a way to make it work?
JW
JW
Hi John,
by using a cutting plane there is no possibility to use rendindering styles like technical or shaded.
Look into the Helpfile Ribbon Interface > Author > Cutting Planes there you find the following:
pardon, but this is no bug it's a Feature ;-)
Regards Dirk
Hi John,
display as Smooth with Outline because cutting-plane
rendering does not support silhouettes.
Regards Dirk
