When I import a part with curves on it and scale it the part scales but not the curves. Is there a way to get the curves to scale along with the part?
If its a 3d Curve save the another copy of the part.
Open that part copy and delete all the geometry except the 3d Curve.
Save this file as an Iges file and in the options make sure the 3d CUrve is checked
Open this new iges file (you should see the curve)
Start a 3d Sketch and convert entities.
Delete all of the convert entity relations.
Now dimension one leg of your curve. It will start out at the original length but once you dimensions it say from 3 to 6 (2x scale) the rest of the entities will follow suit. That's because 2014 and on the first sketch scales then entire model.
Oh and insert part into the other part. If it shifted its easy to lay it back into position.
Can you post the file so we can look at it?
