I use this program for 3 months, but I could not find solutions or explanations to these problems.
1. If I make an animation in SolidWorks Composer, then sometimes it looks a bit different in SolidWorks Composer Player. Everything is "closer" to the view point and the player buttons, which I have always placed in the bottom right corner falls out of the picture in SolidWorks Composer Player. It happens only some animation, in general everything is ok.
2. Sometimes happens that the color of a spare part changes (mostly in the rotation and approximation of view) when I play the animation. After a restart, the problem is over, but that would be good if it never happened.
I hope you can help me.
I thank you in advance for the help!
Peter
1. Are you viewing the paper space correctly? If you don't know what that means its the size of paper you are publishing too. You can hide it but can't see where your items are relative to the paper and the items will be shifted to your perspective of where you think you are placing objects on the paper.
2. I don't know. Guessing you accidentally changed the color and didn't save your work and it goes back. If it happens again click the part and scroll through your animation manually and watch the color swatch to see if it changes colors. If it doesn't then use your Assembly selection tool and select the part again and watch it again.
You can always filter by part and by part properties to quickly see any "keys" that were made for that part if you animation is heavy with keys.
