My hole table is showing negative zero (-0.00) value for the holes coming on either axis. It can be removed by setting the trailing zero to smart, but for tolerance, I need to show in format of 0.00 only, for this solidworks automatically converts it in to a negative number. Just wondering is to possible to remove negative & simply show it as 0.00. screenshot attached.
Old topic, but I had the same problem.
I found out when you select "edge" for your origin you get the minus sign at front of zero. If you select a "point" for your origin the minus sign is gone. Not sure if it's random situation, and I don't see anything wrong with an edge as an origin. I have no idea what the minus sign suppose to mean at front of zero either.
I hope this is quick fix for all cases.
Here is example:
