Is it possible to grab a dimension from a selected line? I have been trying to use the API to get a dimension off of the bounding box line but have been unable to.
I have this line where I am grabbing one of the bounding box lines.
boolStatus = swModel.Extension.SelectByID2("Line2@Bounding-Box2", "EXTSKETCHSEGMENT", 0, 0, 0, False, 0, Nothing, 0)
I have tried to measure it using the swModel.Extension.CreateMeasure code but it doesn't give me a value for some reason.
Any help would be greatly appreciated.
Thanks in advance,
Trevor
I figured it out, i think i had the wrong name selected for the bounding box so i added in some code to check through some possible names.
Hopefully this helps anyone trying to get values from the bounding box.
boolStatus = False
i = 1
Do While boolStatus = False
line = "Line2@Bounding-Box" & i
boolStatus = swModel.Extension.SelectByID2(line, "EXTSKETCHSEGMENT", 0, 0, 0, False, 0, Nothing, 0)
i = i + 1
If i > 100 Then
boolStatus = False
Exit Do
Loop
If boolStatus = False Then
MsgBox "Please check your bounding box", vbOKOnly, "Error, Son!"
End
Set swMeasure = swModel.Extension.CreateMeasure
boolStatus = swMeasure.Calculate(Nothing)
'changes value to IN from system units
length = swMeasure.length / 0.0254
Debug.Print "Length: " & length
