How to insert a filled surface from four 3D curves
Question asked by Tien Dinh on Sep 17, 2015
Latest reply on Sep 18, 2015 by Tien Dinh
Dear all,
I have been trying to write a code to insert a filled surface from four 3D curves. However, it does not work out . Below is my code
Dim boolstatus As Boolean
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swSketchMgr As SldWorks.SketchManager
Dim swSketchSegment As SldWorks.SketchSegment
Dim swFeatMgr As SldWorks.FeatureManager
Dim swRefPlane As SldWorks.RefPlane
Dim swFeat As SldWorks.Feature
Dim selObj As Object
Dim status As Boolean
Dim edges As SldWorks.Edge
Dim a As Double, h As Double, p1 As Double
Dim p2 As Double, p3 As Double, p4 As Double
Dim p5 As Double, p6 As Double, p7 As Double
a = 2 * Sqr(2)
h = 1
p1 = 0
p2 = 1
p3 = 0.2
p4 = 0.3
p5 = 0
p6 = 0
p7 = 1
Set swApp = _
Application.SldWorks
Set swModel = swApp.NewDocument("C:\Program Files\SolidWorks Corp\SolidWorks\lang\english\Tutorial\part.prtdot", 0, 0, 0)
Set swModelDocExt = swModel.Extension
'swApp.ActivateDoc2 "Part1", False, longstatus
Set swModel = swApp.ActiveDoc
Set swFeatMgr = swModel.FeatureManager
swModel.InsertCurveFileBegin
boolstatus = swModel.InsertCurveFilePoint(0, -(a + p1), p2)
boolstatus = swModel.InsertCurveFilePoint(-(a / 2 - p3), -(a / 2 - p4), p5)
boolstatus = swModel.InsertCurveFilePoint(-(a + p6), 0, -p7)
boolstatus = swModel.InsertCurveFileEnd()
boolstatus = swModel.InsertCurveFilePoint(a + p6, 0, -p7)
boolstatus = swModel.InsertCurveFilePoint(a / 2 - p3, -(a / 2 - p4), 0)
boolstatus = swModel.InsertCurveFilePoint(0, (a + p1), p2)
boolstatus = swModel.InsertCurveFilePoint(-(a / 2 - p3), a / 2 - p4, 0)
boolstatus = swModel.InsertCurveFilePoint(0, a + p1, p2)
boolstatus = swModel.InsertCurveFilePoint(a / 2 - p3, a / 2 - p4, p5)
' Insert a filled surface
boolstatus = swModel.Extension.SelectByID2("Curve1", "REFERENCECURVES", 0, 0, 0, True, 0, Nothing, 0)
boolstatus = swModel.Extension.SelectByID2("Curve2", "REFERENCECURVES", 0, 0, 0, True, 0, Nothing, 0)
boolstatus = swModel.Extension.SelectByID2("Curve3", "REFERENCECURVES", 0, 0, 0, True, 0, Nothing, 0)
boolstatus = swModel.Extension.SelectByID2("Curve4", "REFERENCECURVES", 0, 0, 0, False, 0, Nothing, 0)
Set selObj = swSelMgr.GetSelectedObject6(1, -1)
'Debug.Print swSelMgr.GetSelectedObjectType3(4, -1) // returns 26
'If Not selObj Is Nothing Then
'   MsgBox "selObj isn't empty!"
'End If
Set Edge = selObj(0)
Set swFeat = swFeatMgr.InsertFillSurface2(2, swFeatureFillSurfaceOptions_e.swOptimizeSurface, selObj, swContactType_e.swContact, Nothing, Nothing)
If swFeat Is Nothing Then
   MsgBox "swFeat is empty!"
Any help or suggestion is highly appreciated.
Best regards,
Tien
