Hello, I want to get a pdf version (in English) of the SW tutorials. I mean the ones under Help. Mine is displayed in Japanese. I want an English version. I searched SW tutorials on the SW website but something else showed up. Thanks.
Thanks Jamie. I found it but it seems that I have to goto each page and hit the print button to print it. Then, move to the next page manually and print... Is there a way to print the entired selected tutorial?
No problem Peter, when you are in the turorial press the show button on the tool bar:
Then right click on the lesson that you want to print.
You will then be asked what you want to print in this lesson. I have selected to print out everything, so the selected heading and all subtopics.
I have printed mine to PDF but you will see that I have all the pages for the tutorial.
Hope this helps and good luck with the tutorials.
Hi Peter,
If you navigate to C:\Program Files\SolidWorks Corp\SOLIDWORKS\lang\english and double click on a file called swturorial. This will launch the English version of the tutorials.
If it doesn't launch it could be down to a corrupted version of the .chm file. It is also worth checking that you have full access to this folder: I also found a useful PDF for learning some of the basics on the SolidWorks website.
http://www.solidworks.co.uk/sw/docs/Student_WB_2011_ENG.pdf
Hopefully this will help.
