I have a vertical square tube that has an angle welded to it perpendicular to the axis of the tube. I want to put a gusset that sits on top of the angle and flush with the round corner of the square tube. I cannot seem to be able to do that. Any suggestions?
Thanks for the suggestions, I ended up extruding it. What I did was make a 3D sketch that was parallel to the face of the gusset I wanted to create, put a point on the radial surface of the square tube and constrain it so that it put the gusset where I wanted. Then I made my gusset shape and extruded it.
