I have created a custom title block in a drawing template. It contains some basic information, titles and linked properties. When I go to create a new sheet in the drawing the formatting and some of the contents of the title block don't copy through into the sheet format for the second sheet.
For example the Company Logo doesn't copy though, the font and size of the drawing no. changes and some of my fixed notes disappear.
As far as I'm concerned the title block should be identical on every sheet, the only thing that would change would be the identifying sheet number, i.e. sheet 2 of 5 etc....
This happens if I use my sheet template for an actual drawing and also happens in the template itself if you just open that stand alone.
How do I set it so that when I click new sheet the title block formatting also pulls through as part of the sheet format.
Cameron
