Hello, there are lots of mates in my assembly. However, when I tried to use MateXpert under Tools, it is dimmed. Anybody knows how to activate it? Thank you.
Thank you Deepak. I tried to set a distance constraint. According to the mating FAQ, MateXpert should suggest solutions to error. How come I cannot see the suggested solutions? I get an error like:
Cannot move to a position that satisfies this mating constraint. The distance between two flat surfaces are incorrect. The real actual distance is 95.1931253 mm but the desired target distance set by the user is 99mm.
Do you know how to solve this error?
Thank you. By suppressing "some other mate", how do I know which ones to suppress? To find out which ones to suppress, do I have to do it by trial and error. Am I right? There are so many mates to try.
You need to have conflicting mates to use MateXpert
