Okay I have an assembly with 4 parts. One part has many configurations that I would like to be able to switch between easily in my current work flow. I would like to be able to select the desired configuration from a list in the custom property tab. I was able to link the list to the part's design table excel file. Bam done.
But how can I link the custom property to the configuration of the part in the assembly?? Is this possible? I noticed that the display states are linked to the configurations, but I don't know how to call upon them or if that is even possible.
Thanks in advance!
Sarah,
Is there a reason that just selecting the configuration from the tree wouldn't work?
The custom property tab is more for writing custom properties to the file which could be extracted to use in title block / parametric notes etc.
From the sound of what you are trying to do I maybe try using the Configuration Publisher.
