I noticed today that my threaded holes are missing a small section of the circular dashed line. Where is the option to make this a full circle...?
I believe this is an anomaly that is due to the scaling of your drawing view. The software is following rules that tell it how to make the dashed line based on its size, other lines in the area, and other variables. If this is correct, you will have to live with it the way it is (which is trivial in my opinion), or you can scale your view up or down and the dashed line will fill in better.
Maybe the drafting standard of your drawing's document properties is set to anything else but ANSI? Only ANSI Standard shows threads as full circles.
