1 Reply Latest reply on Sep 14, 2015 4:27 PM by Gokan Simsek
    I need a macro to check out latest versions of a list of files from a Workgroup PDM 2014.
    Gokan Simsek
      if I can have the list in a text file that would be great. Is this possible with VBA?
      I'd like to check out a drawing and its model at the same time and copy them to a folder on my PC.
        • Re: I need a macro to check out latest versions of a list of files from a Workgroup PDM 2014.
          Gokan Simsek
          I spent 4 hours for this. I'm posting it so you don't have to. You need to enter your paths info etc
          Sub Main()
              Dim connection As PDMWConnection
              Set connection = CreateObject("PDMWorks.PDMWConnection")
              connection.Login "username", "password", "PDMserver"
              Dim doc2 As PDMWDocument
          Dim dataArray() As String
          Dim i As Integer
          Const strFileName As String = "C:\Users\yourusername\Desktop\list.txt"
          Open strFileName For Input As #1
          dataArray = Split(Input$(LOF(1), #1), vbLf)
          Close #1
          For i = LBound(dataArray) To UBound(dataArray)
              dataArray(i) = CleanNonPrintable(dataArray(i))
              If dataArray(i) <> "" Then
                  Set doc2 = connection.GetSpecificDocument(dataArray(i) & ".SLDPRT")
                  On Error Resume Next
                  Value = doc2.TakeOwnership()
                  Value = doc2.Save("savetopath")
                  Set doc2 = connection.GetSpecificDocument(dataArray(i) & ".SLDDRW")
          Next
              connection.Logout
          insert what's below into a module.
          Function CleanNonPrintable(StringIn)
              Dim Tmp
              Dim Char
              Dim Value
              For i = 1 To Len(StringIn)       'Looping through each character in VarCleanMessageText
                  Char = Mid(StringIn, i, 1)   'Getting a substring of each character, i is the character position, 1 is the length of the substring
                  Value = Asc(Char)                       'Getting the Ascii Value of the character
                 If (Value > 31) And (Value < 128) Then  'This is a valid printable character
                     Tmp = Tmp & Char                    'So add it to our Tmp String
                 Else
                     Tmp = Tmp & ""       'Otherwise, we'll add <ASCII VALUE> in brackets to the string Feel free
                                                         'to replace the brackets with whatever you feel necessary
              Next                                       'Closing our For Loop and going to the next Character
              CleanNonPrintable = Tmp                    'Replacing the original VarCleanMessageText with our new value
          End Function
