hi,
I am suffering from error showing inadequate fixture.
I had getting error while rerunning the simulated assay. by making simple changes in the study like by changing load or load location.
for getting accuracy as compared to actual system i m simulation on assembly from last 3weeks.
by following same procedures while working with my model.
solid works simulation sometimes simulate the model but some times it gives me error.
Kindly help if someone observed such problem.
Rgd,
Nakul
Obviously the software thinks something is moving. Usually this is just because a restraint is missing however, it can seem there is no need when, for the software to solve, a small restraint needs to be added. A simple example is a bearing on a shaft. One would think that just restraining in the vertical direction would be enough but some small restraint, edge or point, needs to be applied to keep the thing from 'sliding' around the floor.
