Parts not getting extracted in order
Question asked by Arvind Purushotaman on Sep 13, 2015
Latest reply on Sep 13, 2015 by Josh Brady
I have wrote a small snippet that extracts the components in the assembly and check if that is an assembly or part by itself and prints all the part names. The command GetComponents gets the components and stores it in an array alphabetically.
Can someone explain me how to extract the parts from the feature tree in the exact order?
My code is as follows:
Dim swApp                            As SldWorks.SldWorks
Dim swAssem                       As SldWorks.AssemblyDoc
Dim ComponentArray          As Variant
Dim Component                   As SldWorks.Component2
Dim swCompModel              As SldWorks.ModelDoc2
Dim swsubAssy                    As SldWorks.AssemblyDoc
Dim subAssyCompArray     As Variant
Dim SubAssyComp              As SldWorks.Component2
Set swAssem = swApp.ActiveDoc
ComponentArray = swAssem.GetComponents(True)
For i = 0 To UBound(ComponentArray)
    Set Component = ComponentArray(i)
    If Component.GetSuppression = 0 Then
        MsgBox "State : Suppressed"
    Else
        MsgBox "Name:" & Component.Name2
        Set swCompModel = Component.GetModelDoc2
        If swCompModel.GetType = swDocASSEMBLY Then
           MsgBox "Component" & Component.Name2
           Set swsubAssy = swCompModel
           subAssyCompArray = swsubAssy.GetComponents(True)
           For j = 0 To UBound(subAssyCompArray)
               Set SubAssyComp = subAssyCompArray(j)
               If SubAssyComp.GetSuppression = 0 Then
               Else
                  MsgBox "Name:" & SubAssyComp.Name2
           Next j
Next i
Thank you
