I'm having trouble getting a cut to follow a curve. For some reason the cut won't offset from the curved surface. Any ideas???
Craig,
Are you trying to make cut extrude 55 a cut which follows the curvature of the top face?
A way you could do this is first create a offset surface (in the offset toolbar) of the value you want to cut to. Then in the extrude cut option select upto surface and select the surface just created.
Stephen
Craig,
Stephen
