Here comes the newbie again.
I have an extruded circle 0.250" in diameter, meeting a triangular shaped body (think arrow shaft and arrow, respectively). The Arrow is only 0.200 thick so a bit of the diameter of the shaft extends beyond the surface of the arrow. I'd like to create a nice filet or at least a ramped joint there rather than the blunt face of the cylinder/shaft. How can I do that?
You should be able to add fillets on the edges and around? If you can attach the file itself then someone can play with it.
