1 Reply Latest reply on Sep 10, 2015 5:56 AM by Simon Turner
    Run Windows Form App at Login
    Matthew aDAMS
      I have written an add-in that display a Windows Form Application when the Add-in loads or using a menu command.  Works great but I did not know that the add-ins load more then just when you vault is first logged into.  I would like this to only run after you have logged in or when you select the menu command, not every time the add-in loads.  Can anyone point me in the right direction?
      Here is the Code in VB that I am using:
      Imports System.Windows.Forms
      Imports EdmLib
      Imports System.Collections.Generic
      Imports System
      Public Class UpdateCommon
          Implements IEdmAddIn5
          Public Sub GetAddInInfo(ByRef poInfo As EdmAddInInfo, poVault As IEdmVault5, poCmdMgr As IEdmCmdMgr5) Implements IEdmAddIn5.GetAddInInfo
              ' Specify add-in information
              poInfo.mbsAddInName = "Show Windows Form:"
              poInfo.mbsCompany = "Some Company."
              poInfo.mbsDescription = "Show Windows Form:
              ' Specify minimum version of SolidWorks Enterprise PDM
              poInfo.mlRequiredVersionMajor = 6
              poInfo.mlRequiredVersionMinor = 4
              Process.Start("D:\EPDM_Addins\test\CommonUpdate\App.exe")  'Display Windows Form at login
              ' Register a menu command
              poCmdMgr.AddCmd(1, "Run App", EdmMenuFlags.EdmMenu_Nothing)
          Public Sub OnCmd(ByRef poCmd As EdmCmd, ByRef ppoData As Array) Implements IEdmAddIn5.OnCmd
              Process.Start("D:\EPDM_Addins\test\CommonUpdate\App.exe")   'Display Windows Form from Menu
      End Class
      Thanks!
      Matthew
