Is there a way to set the opacity of the lines in silhouette or flat technical render modes so that they outline fades in correctly along side the color opacity? Currently, when I do a fade in, using the regular opacity setting, the lines flash on and off rather than fading in correctly like I would expect. I look for an opacity setting in the outline section, but there was none. I could just go from white to black line color, but that's not what I'm looking for.
The lines are construction mode.
This is how it actually looks:
And this is how I want it to look (done in premiere):
Here is a close up of this blink effect.
Well, nothing so far. One thing I started doing was doing the fade in Premiere for the few places (or more) where I really wanted one. The only time it is a pain is if there is an animation, in which case I have to take two videos, one where the part is there and one where it isn't, and then fade from one to the other. If nothing else is moving I can just make it appear in composer and then do a simple opacity fade on the frame in premiere so that it appears to fade in or out.
