Hello everyone. I am a new user of solidworks API with some programming background. I actually have been able to create some useful macros with success. But I am struggling with one problem that I cant seem to find a solution. I hope you guys can help me.
I have attached the macro so you guys can have a better look at the coding. I am sorry about the number of comments, but as I said as a new user I have to do a lot of experimentation before ger everything up and running smoothly.
So let me try to explain my struggle to you.
I have created a macro that check which parts of an assembly do not have its respective drawings (Knowing that the drawings have the same name of the parts and are located in the same folder. So when I run the command for the buttom Open Part it just dont work. After some hours of trying to find a solution I realised that the long warning variable was returning 128, which means that the part is open. The thing is: I have JUST the assembly document opened. If I create a new macro and run just the bit of OpenDoc6 it works normally. But if I have the Assembly opened and try to run the command it gives the warning and nothing happens. What I really dont understand is that it worked before, and I changed some other parts of the code (The create drawings command if I am not mistaken) and then it suddely would work anymore.
I will paste right here the command buttom code and will attach the full macro as well. Hope anyone can understand this, because after some hours spent trying to solve I really am sutcked and cant move on.
Thanks in advance.
Sub OpenSelectedPart(bViewOnly As Boolean)
Dim fileerror As Long
Dim filewarning As Long
Dim sSelectPath As String
Dim sSelectName As String
Dim sSelection As String
Dim strRefConfig As String
Dim sDocType As String
Dim sCompConfig As String
'Get full path of selected part from list box
' sSelectPath = listMissingDrawings.Column(2, listMissingDrawings.ListIndex)
sSelectName = listMissingDrawings.Column(1, listMissingDrawings.ListIndex)
sCompFileName = Mid(sSelectPath, InStrRev(sSelectPath, "\") + 1)
Debug.Print sCompFileName
' Get Used Config
sSelection = GetSelectionName(sSelectName, sRootCompName)
boolstatus = swAssem.SelectByID(sSelection, "COMPONENT", 0#, 0#, 0#)
Set swSelPart = swSelMgr.GetSelectedObject(1)
'strRefConfig = swSelPart.ReferencedConfiguration
sDocType = LCase(Mid(sSelectPath, Len(sSelectPath) - 6))
Debug.Print sSelectPath
Debug.Print sDocType
swApp.OpenDoc6 sSelectPath, swDocPART, swOpenDocOptions_Silent, sCompConfig, fileerror, filewarning
If filewarning = 128 Then
MsgBox "Component is already opened!"
If sDocType = ".sldprt" Then
swApp.OpenDoc6 sSelectPath, swDocPART, swOpenDocOptions_ReadOnly, sCompConfig, fileerror, filewarning
Else
swApp.OpenDoc2 sSelectPath, swDocASSEMBLY, bViewOnly, bViewOnly, True, fileerror
